Need help!!
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,674
The one with the double coil.
Retired and loving it.
  • David Tetreau
    David Tetreau Member Posts: 15
    This piped object is on a steam system, with the steam header connected to the left side. What is this?
  • DanHolohan
    Excelso
    made indirect heaters.
  • bob young
    bob young Member Posts: 2,177
    steam trap
    Looks like a float & thermostat steam trap. very strange f. & m. hangers though.at first it looked like 1/2 " lines were connected to 2 " piping. gotta be a trap
  • DanHolohan
    Excelso
    didn't make traps.
  • bob young
    trap or coil --looking good
    maybe the guy that installed it could not get a trap and installed a coil instead , collected his cash and called it a day. the hangers alone are worth at least a thousand. not every dead steamfitter was a genius. i have seen more than a few puzzlers in n.y.c.
    Steamhead Member Posts: 18,140
    That's the same one
    pictured in the "what is it?" thread. Since the return connection (seen above dirt leg) is plugged, it's safe to assume this hasn't worked in years.
    It was probably used to heat water in an overhead tank by gravity.
    Consulting
