Is this sufficient?
Nick_9
Member Posts: 14
Hello all, I will be installing a wood burning stove in my basement. Code states that it has to be 6" away from all walls. I have a question. Even though it will be 6" away from the walls..is fire rated drywall..5/8" 4x8 sheets sufficient enough for the heat of the stove or should I cover the drywall with something else? Thanks. Butch
Fire rated drywall
Hello all, I will be installing a wood burning stove in my basement. Code states that it has to be 6" away from all walls. I have a question. Even though it will be 6" away from the walls..is fire rated drywall..5/8" 4x8 sheets sufficient enough for the heat of the stove or should I cover the drywall with something else? Thanks. Butch0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
