bock water heater setup
If it can wait until Monday and no one else has the info by then here's the fella to contact.
George M. Kusterer - Director of Technical Services
Bock Water Heater Co.
Phone (610) 683-9206
E-mail: Gmkusterer@cs.com
Your friend in the industry,<BR>Alan R. Mercurio<BR><BR><a href="http://oiltechtalk.com/discuss/index.php?sid=63c67a82829fdbdda388591b32998104">www.oiltechtalk.com</a>
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    bock water heater setup?
    well i had a fun mourning 2 Bock #361e water heaters-that were plugged--fire department came in @2:00 a.m. and shut them down--started a 3:00 a.m. got done at 7:00 brushed out and powerwashed---- 1 is up and running fine--wayne burner--the other is a Beckett SF -the heater only lists the Carlin and the Wayne -- i'm hoping some one has some info on the set-up or some specs in the application guide -the guides i have do not show them -----i'm looking for the basic set-up and "starting point" --head,nozzle angle,type -air tube length -- right now i've got 100 psi pump pressure 3.00 80* h nozzle(angle doesn't seem right) f-31 head and a 9-1/2" air tube(seems too short)this is only 2-3 years old and never ran right according to the super --
  • oil-2-4-6-gas
    thanks, i received an e-mail from him regarding this
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
    You're very welcome.
    Alan R. Mercurio
    www.oiltechtalk.com
