Triangle Tube
Weezbo
Member Posts: 6,231
Tube for justabout any contrived need *~/:)
Triangle Tube
May try Triangle Tube Delta Performance Combination domestic/space heat unit for radiant addition with bath and laundry. Anyone have pros or cons on these?0 -
well i like them...
*~/:) or who ever i am today
)) oops ..i would steer clear of the combi units or add additional storage were i considering jet tubs that gobble up gallons and gallons of hot water..or add a pre heat heat exchanger and recirc system specifically for the fixture. thats because they are only having Xamount of hot water after which a brief six mins or so they are back on track again...so if you explain that they are energy efficent and the need to not waste energy is on the agenda people seem to "Get IT'and are happy with them..to date, the most occupied home that i have installed one in has about 3 adults and one child, the rest of them are married couples mostly older and probably well aware of the prices of fuel oil over the years...and none have any complaints... 0 -
Triangle Tube and high DHW load
Yes---we sell Triangle Tube combos because of the tank-in-tank design, as opposed to coils or plate-type heat exchangers. But true, combos don't have much dump capacity. How about their Smart Series indirects? Again, tank-in-tank. Inner tank is corrugated so it's self-cleaning and self-descaling, but more importantly, greater heat exhange surface gives quicker recovery. Indirects stash 180-degree water, so they can deliver more DHW in a hurry, and occupy less space than a standard HWH. And you're still heating water at the efficiency level of your boiler.0
- 167 Indoor-Air Quality
