Tain Breezer
Aidan (UK)
Member Posts: 290
Tobacco calorific value 15000 kJ/kg
Will you convert that into BTU per fag please Weezbo ?
http://www.vt.tuwien.ac.at/biobib/fuel245.html
Btu's
How many Btu's are given off by one cigarette?
Hmmmm
Is that burning or in the pack?
If burning is it idle in the ash tray or in the process of a big drag?
Standard or virginia slim?0 -
standard
leisurely smoke - not the frenzied suck-on-it-till-there's-a-two-inch-long-glowing-ember you see when truly addicted smokers first get off a long flight!
One cig gives off 1-gram of smoke particulate matter, but I'm curious about the Btu load it adds indoors. Energy costs to filter and condition the air in clubs or restaurants.
Here is a site
that appears to have the info you are looking for. It is all in metrics though so get out the Heating Helper to help convert it. The info you are looking for starts on page 4 of this document.
http://searcht.netscape.com/ns/boomframe.jsp?query=cigarette+temperatures&page=1&offset=0&result_url=redir?src=websearch&requestId=b330f9f160d91b84&clickedItemRank=1&userQuery=cigarette+temperatures&clickedItemURN=http%3A%2F%2Fwww.bfrl.nist.gov%2Fpdf%2FTSG_2_Krasny.pdf&invocationType=-&fromPage=NSCPTop&ampTest=1&remove_url=http://www.bfrl.nist.gov/pdf/TSG_2_Krasny.pdf
Glenn Stanton
Manager of Training
Burnham Hydronics
www.burnham.com0 -
Alrighty
25 Btu's per smoke,as my rough guess, 500 Btus per pack smoked to the filter. 100 smoking patrons 1 night in the club 1 pack per smoking patron equals 50,000 Btus per night......Priceless. Using Btu content of coal as my base since no Btu content exists for tobacco. Cigarette is about 1 gm of tobacco. 12500 Btu's per pound of coal, 781.25 Btu's per ounce,27.91 Btu's per gm.
Gordy
Dave
Did you come up with a number?0 -
not yet
but at the temps listed (as Glenn said, they begin on page 4), I'd have to think it'd be more like 200+ Btu's per smoke. Unattended, they used to take about ten minutes (evidently most now will extinguish themselves as a "safety feature" - an oxymoron if ever there was one!) to burn down to the filter.
Having once had a lit cigarette in my pants pocket in order to avoid getting suspended from school, I can attest to the fact that they burn through clothing and skin quite effectively!
Also add
the BTU's given off by the match or lighter used for ignition
hot rod
The increased frustration and heat produced from frenzied
searching for the tobbacco and ignition source
Based on Aidan's number
I get 14 BTUs per cigarette. A wooden kitchen match is one BTU. bob0 -
filitration
Latent heat from filtration system? Extra exhalation in the smoking process?0
- 167 Indoor-Air Quality
