Insulating underground hot water pipes
I'm getting ready to install a wood fired hot water boiler in my shop (garn or AHS I think), and I'll need to run hot water and return lines to my house about 120 feet away.
I want to lay 3/4" copper lines, solder the joints, and insulate them with foam pipe insulation, then encase both in a single 4" plastic pipe. I'll bury this well below frost line. The lines will be part of a closed loop system, and will have glycol in them. Its heat loss, not freezing, that I'm concerned about.
The system will provide primary heat for my radiant in floor system in the house, and heat my woodshop as well.
Is this insulation adequate? What kind of insulation is required, and what products should I use in this application if my idea won't work?
Finally, can I use copper with soldered joints in a hot water system? I expect water temps to be less than 180 deg.
Thanks for your input. With rain coming, I need to get my pipes in the ground next week!
Wayne
waynec@gorge.net
