PEX for older system?
Brian Tober
Member Posts: 18
Thanks for the reply. Let me clarify what I was thinking of doing. It is a hot water system with 3 zones that have iron pipes for the main loop with 2 pipes off the main with diverter Tees to each Rad. Can I run new mains using Rigid PEX pipe or the PEX AL pipe in the crawlspace basically just duplicating what exisits using plastic pipe? If I could use flexible rolled PEX in the crawl as the Main loop that would be awesome so I wouldnt have to solder elbows at every twist and turn. What size main would you use? It has 1/2" branches now to each Rad. now. Would 1" be good with 1/2" branches?
PEX on older system
I am replacing a boiler with 3 smaller ones in our apt house so tenants will each have sep. gas bills. The house has cast iron radiators already in 3 sep. zone loops with sep. circulators so it should be pretty smooth conversion. The system uses diverter tees off the main loop to each rad. I want to replace all the old piping in the crawl space since its really old iron pipe with repair patches all over. My question is: Can I use PEX pipe for the main loops and branches to each rad? I guess they dont make Pex diverter tees for the branches tho so i have to use the standard kind. Can I run PEX right up to the boiler? This would be a huge time saver for this project but I never used pex before. Thanks for any advice!0 -
I wouldn't use PEX on a diverter-tee system
but they do still make copper diverter tees- that's what I'd use. This type of system relies on proper pressure drops which are inter-related. Since PEX is flexible, the pressure drop in a given length could change, affecting water distribution.
Repiping the system as two-pipe with PEX might be an option here, but the rads at the end of the diverter-tee loop might then be a bit oversized since in the diverter-tee system they were fed with slightly cooler water. You could cure this with TRVs if they're not in the room with the thermostat.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Home Run system
You could gut the piping, and do a home run system to each corresponding boiler with pex manifold. This would also reduce the temperature drop that you would have with a monoflo system.0 -
Pressure Drop
I would seriously doubt that the expansion or contraction of PEX tubing would have a significant if even measurable effect on the pressure drop in a system or circuit. A home run application bringing each rad back to a manifold would give the ability to tune the flow without the use of diverter tee's.
Tim D.0
