drop header
Jim Pompetti
Member Posts: 552
I need a good drawing of a drop header. I'm a poor artist
I have a few
Sent to me by Noel Murdough , Glenn Stanton and other fellow Wallies for some trouble I had with a local inspector .0 -
There are also
some photos of drop header jobs, in the Library under "Steam Piping".0 -
drop header
If you need clean copy and this would do,I should be able to save this in almost any format. Just let me know. Original is in Visio (.vsd)0 -
If this would do, I should be able to give you a clean copy in almost any format. Original is in Visio (.vsd)
Also, think I have single riser but would need to look. May have only kept it in .pfd format.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
