Cast Iron Radiators
TGO_54
Member Posts: 327
That I know of, however it is easy enough to get the exact output of the radiators. Go to the left toolbar and click on books and more. Order a copy of EDR - it has the information you need.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=278&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Cast Iron Radiators
Is there a general rule of thumb to figure out how many BTU's of heat you can get from a cast iron radiator.
Say for example if you had an old cast iron radiator that is, say 30 inches long and say 2 foot high.(example only)
How can I figure out which radiator to use in a room if I
know the heat loss for that room. Lets assume I can run any
size pipe I want to it. ie 3/4, 1 inch etc.
Thanks,
Steve0
- 167 Indoor-Air Quality
