GB 142 temp-mix
Al Taft
Al Taft Member Posts: 2
There are two sides to the GB142,the space heating side, and the DHW side.In this project we have in slab radiant w/hydro air as a secondary or "back-up system".The GB is condensing,so let it condense.Put the hydro on the other side,the DHW side.Don't mix down!Run the radiant only on the low side,and watch it condense.
  • Al Taft
    Radiant and hydro-air with the GB142
    There are two sides to the GB142,the space heating side, and the DHW side.In this project we have in slab radiant w/hydro air as a secondary or "back-up system".The GB is condensing,so let it condense.Put the hydro on the other side,the DHW side.Don't mix down!Run the radiant only on the low side,and watch it condense.Only thing: How can I keep Modulation? Look at setup @ my site. www.eurotechheat.com
