buffer tanks
hr
hr Member Posts: 6,106
SuperStor used to offer a SSU-20 20 gallon four4 1-1/2" ports, aquastat well and top tap. Lochinvar has a series of tanks billed a s buffer and air elimintor tanks, not sure they go that small however.e
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • adroit
    adroit Member Posts: 2
    buffer tanks
    Does anyone have any information on a 20 or so gallon buffer tank that is actually made as a buffer tank with four 1 1/4" ports and maybe an aquastat well and an air seperator port? Thanks
  • adroit
    tube over a slab
    What are all y'all doing to attach tubing to a new or existing slab? What is your total target build-up?
    Mesh over bubble-foil-bubble insulation and then hilti pinned to the slab or have you used any of these styrofoam type tube mat thingies? Thanks
  • hr
    HTP
    SuperStor used to offer a SSU-20 20 gallon four 1-1/2" ports, aquastat well and top tap, as I recall.
    Lochinvar has a series of tanks billed a s buffer and air eliminator tanks, not sure they go that small however.
    hot rod
  • hr
    HTP
    hot rod
