Corn burning boilers
kevin_5
Member Posts: 308
I agree with you Steve, not very efficient compared to a Tarm. Also, Heatsource one will sell direct to my customer if I did convince him he needed one. They can buy it as cheaply as I can. Some wholesalers do the same thing. Paul was the best. I miss him! Kevin
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=270&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Anyone have any real experience with corn boilers, specifically the outdoor type. I'm looking for a good shelled corn unit or line that is at least semi automatic. As in, hopper fed with automatic water temp regulation. If you have one you like, let me hear about it.0 -
could not resist the comment!
Why would any red blooded heating tech want a CORN fed boiler, unless it was himself! Oh you mean the dry corn not the LIQUID Corn!0 -
I don't know....
about the outdoor type but HS Tarm has a very nice inside one that does those things....kpc
Heatsource 1 here in Nebraska makes a unit
that is has an automatic feed auger system. They make this unit (without the auger) for coal and wood as well. Pretty nice stuff. I used to sell them B&G pumps for their units when I was on the other side of the counter as a wholesaler. I'm pretty sure they have dealerships across the country. Here is the link.
http://www.heatsource1.com/
Regards,
PR
Burns best sells one
It's called a Pelco. It burns coal wood pellets or corn. Take a look www.burnsbest.com or www.Profab.org I've not yet installed one.0 -
Shop for a gasification
type boiler. Much more efficient and less emissions. I've yet to see and outdoor model, however. The Tarm is the only corn feeder in the high efficiency range that I have seen.
Farmers around here tell me the "bad" corn supply is not very stable. most would prefer to sell it as food or feed. make sure your unit can also handle wood or pellets if the corn is not available.
Pretty easy to build a shelter to enclose one if it needs to be outdoors. I have a portable shelter company build enclosures for me. This one is my FarmFest demo. They built it with metal inside and out for better fireproofing and looks. It's about 6X8 and fits a Euro gasification boiler.
Many insurance companies insist on outdoor locations for wood fired boilers. Always check with your customers carrier. UL or ASME may also be required.
hot rod
Looks nice
I'm sorry Hot Rod and no disrespect is intended, but wouldn't that make one hell of an out house? The ladies would kill for a nice unit like that.0 -
I can't help with the outdoor units but, in the last three years I've run a different indoor unit each season. The Tarm unit is the one we're going to sell. What kind of questions do you have.
Terry H.0 -
Us Plumbers....
We always know when it's corn season......
tom0 -
corn
Steve what are you doing asking about corn boilers?
THP
Don't go Pelco yet.0 -
corn burner
Heatsource1 has corn burner models in 3 sizes. Over the winter they have modified their units with several nice features. They are due to release them near the end of May. I am a dealer for Heatsource1 located in south central PA. Feel free to e-mail me at tesllc@earthlink.net for more info. Matt0 -
The local hardware store
Sells Heatsource 1 products. They're OK, but like a lot of other equipment in this genre' the efficiency is poor and they are not very clean burning. I'm looking for something that's a cut or three above the field.
Although the Tarm units, and Garn for that matter can be enclosed, I find that most customers want a unit that doesn't require a lot of additional work to install. Just set it on a pad, plumb it and build a fire. Typical Northwoods Michigan. Crude and not too effective. Just throw more wood.....or whatever in the thing and fire it like crazy. Wasteful at best. A lot of needless work besides.
But hey; it's the American way. Buy the cheapest thing you can get your hands on and then wonder why it's worn out or broken in 5 years.
I'm still looking...............0 -
Terry H
I would be interested in which brands you used and what criteria/features caused the Tarm to come out on the bottom of the heap. I have looked around at specs and was definately favoring the Tarm.0 -
Actually
I said the Tarm unit is the one that I am going to sell above all others. It is definately the one to buy.
Terry H.0 -
Sorry Terryh - I read the sell as "getting rid of".0
