Winter Simulator
Paul Rohrs
Member Posts: 357
I would invest in the 002 simulator.
The tekmar 079 slab sensor pdf file has the Ohms resistance readings that correlate to outdoor temp. Here is the link.
http://www.tekmarcontrols.com/acrobat/d079.pdf
Regards,
PR
ps- here is the link for the 002 simulator
http://www.tekmarcontrols.com/acrobat/d002.pdf
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=353&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Regards,
PR
Tekmar 262
Can anyone tell me how to determine the required resistor to simulate winter temps on a Tekmar 262?
TIA, Jed0 -
Tekmar D002
Jed,
Tekmar makes a temperature simulator the number is D002, if you work on Tekmar it is a great tool to have.
S Davis
Apex Radiant Heating0
