buffer tanks
hr
Member Posts: 6,106
SuperStor used to offer a SSU-20 20 gallon four4 1-1/2" ports, aquastat well and top tap. Lochinvar has a series of tanks billed a s buffer and air elimintor tanks, not sure they go that small however.e
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
buffer tanks
Does anyone have any information on a 20 or so gallon buffer tank that is actually made as a buffer tank with four 1 1/4" ports and maybe an aquastat well and an air seperator port? Thanks0 -
tube over a slab
What are all y'all doing to attach tubing to a new or existing slab? What is your total target build-up?
Mesh over bubble-foil-bubble insulation and then hilti pinned to the slab or have you used any of these styrofoam type tube mat thingies? Thanks0 -
HTP
SuperStor used to offer a SSU-20 20 gallon four 1-1/2" ports, aquastat well and top tap, as I recall.
Lochinvar has a series of tanks billed a s buffer and air eliminator tanks, not sure they go that small however.
hot rod
HTP
hot rod
- 167 Indoor-Air Quality
