Ductulator
J. Francis
Member Posts: 3
Does anyone know where to find a ductulator (sp?) or something similar on line to help me size some duct work?
Check here
www.acca.org...may I suggest the manual D system and application.Also understanding the friction chart is a good read as well.
Francis
keep in mind that all duct are not the same,so when using
ductulator you want to have the one for the material you are
using.
Also keep in mind that most ductulator are base on fiction
loss per 100 ft.All duct system are not the same,just as all
duct material are not the same.
Also if you get into the habit of doing a friction worksheet
per job,you'll find not only do you offer a better distribution system,but you have the math to address any issue as well.
R.E. Michels
Sells them, Along with most Hvac supply houses.0 -
ACCA
ACCA
Acca sells a nice one that will also give you the cfm ratings for flex and duct board if you run into it. It is a circular dial type and sells for about $40.00.0 -
your locat trane dealer
should have one for about $5 or you can go to mcquay.com and download one onto your computer.0 -
GEE my suppliers gave them to me for buying their duct
Ductilater
All the majors have them available-Lennox, Trane, Carrier, York,etc., as well as the RSES, ACCA, SMACNA, duct materials suppliers, HVAC suppliers,etc. Your local supply house should be able to get you one.0 -
link to
ductalator doesn't work.0 -
ductolator
If you want to drop me an e-mail with your info, I'll send you one out.0 -
Air Duct Calculator
Just ordered one from ICP - International Comfort products.
It is kisted under the Fast Parts program. Part # 2146347.
Hope this is of some help.0 -
got it.
thx0
- 109 Chimneys & Flues
- 975 Plumbing
- 387 Solar
- 17 Recall Announcements
