REVERSE RETURN SYSTEM
Chuck Mac
Member Posts: 8
You can't pump steam?
My Grandfather once sent me to get a bucket of steam !!
LOL sorry I couldn't resist
Never heard of a dead leg on hot water must be dead heading
I guess
I guess
On a REVERSE RETURN system, the architect refers to a DEAD LEG in the condensate water piping. Can anyone please ellaborate on a DEAD LEG ?0 -
Dead leg?
I'm still confused by condensate in a reverse return system.
What kind of machine might we be talking about?0 -
Dead Leg?
Reverse return system is a piping scheme used on hot water heating systems. A similiar piping detail is used for multiple hot water heaters. Both are very effective methods of balancing flow.
Did the architect mean drip leg?
A drip leg would be used to catch moisture or sediment in gas piping or a steam system.
Keith0 -
Dead leg, refers to
A pumped system where the pump is running with no place for the flow to go. Two pipe reverse returns can do that if a scheme is not worked out for the minimum flow to always continue. I think the engineer confused the issue when he mixed the word condensate into the reverse return technology. Two different cats. Condensate is a steam htg. term and two pipe reverse return is a hot water term. (by the way you cannot pump steam.)0 -
Thanks, Gary
But what kind of machine IS he talking about?
and.....
WHERE THE HECK HAVE YOU BEEN????
Great to see you back!!!
How are you doing?
Noel0 -
Been here
but the computer thing had me off for a while, and then there is health. It is nice to B Back!0 -
Why is..
Why is the architect designing the piping?
I have no idea what a "dead leg" is either.0 -
refering to dead heading?
If this is what he is talking about, than either a wild loop or pressure actuated bypass. You need to call and clarify, as has been mentioned, he is mixing terms0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
- 45 Industry Classes
