Best Way for Cutting Steam Pipes
ed wallace
Member Posts: 1,612
hi speed at the threads before the elbows at ceiling no oil
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
This weekend, I need to cut the pipes on my boiler to prepare for the asbestos removal contractor who needs to remove the sheet metal casing on my 70 year old steamer.
I will be cutting 2-1/2 inch pipes with a sawzall. I have the correct blades but I need to know what speed I should use? Do I use oil as I do when drilling or tapping? Should I use much pressure on the saw, or just a little? I want to avoid breaking blades and learning the hard way!
Thanks!0 -
great answer
mild pressure. You'll feel it.
Noel0 -
Sawzalls good
Youll catch on. Band saw is another option. Good luck.0 -
if you do this with a sawzall you will disturb the asbestos from the vibration --exposing anyone in the house after to asbestos fibers check out your local rental center and rent a pipe cutter preferably a 4 wheel or better yet --if you know how to use 1 rent a cutting torch--just don't burn the house down no matter which way you go make sure you support the piping before hand -0 -
BEFORE....
Cutting any pipe that is attached to anything containing "fire retardant material", take a spray bottle(or hose)and SOAK all the material that may be shaken by the movement of the pipe and/or cutter. The wetter, the better. Chris0 -
EYE PROTECTION
Thanks for all the tips. There is no asbestos and I have installed good pipe hangers into the rafters to take the load of the pipes. This weekend we go to work.0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
