Burnham Web Site
Ron,
I am trying to download a manual for a V907. It is a light commercial cast iron sectional.
For some reason I can not open the site. Every other site I try opens fine. Maybe the problem is on my end.
Thanks,
Ed
  • Edward A. (Ed) Carery
    Edward A. (Ed) Carery Member Posts: 138
    Burnham Web Site
    Glenn, if your are here, Is the Burnham site down?
    I am trying to download an I&O manual.
    I can not log on to anything in the Burnahm site. No other problems with anything else in any other site.
    Anyone else having the same problem.
    Thanks,
    Ed Carey
  • I just downloaded
    the instructions for the V7 , went smooth . Which manual were you trying to download Ed ? Maybe I can get it an email it to you ?
  • Tried to email it
    but the file is too large ( damn AO-HELL ) . I just downloaded the V9 manual , only took a few seconds with this cable hookup . Hope you get through Ed .
    Manual
    Ron,
    Thanks for trying. I have cable too. I just can't open that site.
    I just tried my wife's computer, thinking that maybe the settings on my computer were too restrictive. I also could not open it on hers.
    Can you send my the link to the PDF file itself, maybe I can go directly to it.
    Thanks,
    Ed
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Ed,
    I just e-mailed it to you.
    Retired and loving it.
    I am sorry for being a pest
    Ron, that link would not let me access the file. I am not sure why.
    Dan, I got the file that you sent but it contained 0 bytes. It was empty. Nothing to open.
    I am starting to get a complex about this : ) .
    Thank you both very much for trying. I'll call Burnham tomorrow and try to sort it out.
    Best Regards,
    Ed Carey
  • Ed
    I'm not sure why you can't access the site as it is working for me as well. Let me know your address and I will have them send one out for you tomorrow if that will work.
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    www.burnham.com
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Ed, let's try this
    I will attch the file to the wall. If you can't open it this way, then I would suggest you removal and reinstall Adobe Acrobat Reader.
  • Glenn Harrison_2
    Ed, just a thought
    You might want to try removing and reinstalling Adobe Acrobat Reader. Your reader might be the source of the problem.
    Thanks Glenn
    I will thy the Adobe re-install.
    In the interim, Melanie from you company has already contacted me directly, informing me that she has made arangements to send the hard copy of the manual.
    Glenn, thanks for you help. As always you and Burnham are right there to help when needed.
    Best Regards,
    Ed Carey
