Flexible Hydronic lines
hr
Member Posts: 6,106
this? Watts Radiant was playing around with some braided Onix. Also try hydraulic hose supply and manufactures.
Fluid Master makes braided supply lines for faucet supplies. Not sure how large of diameter or temperature rating. Must be at least 140° F. Very flexible, however and the compression nuts are already installed!
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Does anyone know of a company that sells some kind of braided lines for hydronic use. Something so that panels rad or free standing rads can be taken off of the wall. I have a customer that is interested in this.
PATRIOT HEATING & COOLING, INC.
Multi-core
Ted,
We use Wirsbo Multi-core and leave a little slack under the floor so you can lift the rad off the brackets and lean it away from the wall for painting ect.
Not the same as a braided flex but it works.
S Davis
Apex Radiant Heating0 -
Metraflex?
Twin City Hose?
Parker?0 -
VIessmann flexible piping
Viessmann flexible steel piping c/w two unions and 3/8 insulation.Suitable for connecting domestic hot water tank (heat exchanger side only) to boiler connecting manifolds and piping of otherwise inaccessible areas.
for hot water system up to 248 f and 60 psi.
inside pipe diameter 1# union connections 3/4 only for use
in hot water heating system 6 different lenghts from 12 1/2 to 59 1/40 -
Thanks for the responses.
try
Peerless Mill Supl Co (716)852-4784
79 Perry
Buffalo, NY 14203
- 120 Geothermal
