Weil-McLain Model 80
clammy
Member Posts: 3,242
I've only used the series 80 for steam job and the largest 215 i've installed is a 215 5 section but have install 880 and if it where mine i'de put the buderus in for cleaning it's light years ahead of weil .Plus bettwer insultion jacket and no target or combustion matting and 3 pass good luck and peace clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Can anyone provide the efficiency rating on this boiler (Weil-McLain Model 80 380) and compare it to Buderus G-215/7. What would you choose?
Thanks0 -
Thanks0 -
I have install both
They both have there strong points, but the over all eff. goes to the Buderus, most of all if you use the 2107.When i use the 80 series i instll a 6006 to stop the circs from running till boiler reaches 140*0 -
The 380 Weil
Oil--82.8%. Gas--80.4%. We have installed a dozen or so. Nice water boiler.
80 efficiency
What type of efficiency rating are you looking for? Combustion, afue, seasonal?boilers above 300,000 btu's are not required to post an efficiency rating according to the DOE.0
- 167 Indoor-Air Quality
