More stuff from ISH Boston
hr
003 shows the guts of a drain water heat recovery HXer. 004 is the AO Smith water hearter with external HX.
The company that build those plastic checks seen in pumps and iso flanges had a colorful display. 005 & 006
A nice transfer pump, 007 for hydroniticians. I like the prime port, missing from the earlier versions, as these will not self prime especially with thick glycol! That prime port would be ideal for adding cleaner and inhibitor chemicals in small doses! I think this is an aluminum bodied.
Think of the smiley faced fun you could have with these pancake expansion tanks :)
020 21 22 A water powered back up sump pump. Unless you are on a well pump :) Same manufacture had a 12V transfer pump.
The company that makes the inducer fans seen in most all the condensing boilers had a nice display. Nice to see them supporting the boiler builders at ISH.
A bunch of unique panel radiators, from Turkey I believe.
The manufactures from China 012 walked the Toronto and Vegas shows then showed up in Boston with a copy of almost everything they laid there eyes on. One booth had a wild shower heat collection, sorry no pictures. Unbelieveable prices. A friend of mine made an offer to buy the entire booths worth!
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Chong Gua cong ren yoh zui hao cong fu ..:)
those are some pretty fancy headers the Chinese are making
Weezbo
Can I get that with Rice ?
thanks
love the pictures , sorry I missed the wedding . Love the wall heater with the mirror0 -
> _A
> 237&Step=30"_To Learn More About This
> "Find A Professional"_/A_
For you , the cooks assure me you will also have your choice of SpringFestival Cake or Zhaozi as well
Enjoy... 0 -
Those mirror surrounds look particulaily impressive also eh...? it would be great if dancin girls came with....that may be wishful thinking on my part
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
