Automatic Water Feed Problem
Jason_17
Jason_17 Member Posts: 2
Hello,
I have a very old steam boiler with an automatic water feed. I release waste water thru a valve but never have to add any water. When this happens, the red pop-up on the water supply goes down and as water feeds the system, it pops back up. The last time I released waste water, the red-pop up went down and has not popped up for over a week now. There seems to be no water in the glass gauge. Any ideas on fixing this?
Thanks,
Jason
  • ED_29
    ED_29 Member Posts: 11
    Water feeder
    Do you have a valve closed, before or after the feeder??? If not,there is a strainer in the #101 H/W. Could b pluged up? OR it just needs replacing !
  • Also does your boiler run for hot water? If not, do you have any of the power switches turned off for the summer?
    - Norm
  • Jason_17
    You were right, a water valve was closed before and after the feeder. Thanks
