Central Boiler
Ken_8
Ken_8 Member Posts: 1,640
Never heard of that one however.
Scotch marine type? Fire tube, water tube?
Boiler make the same as the burner make (that would almost be a first).
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • S Davis
    S Davis Member Posts: 491
    Central Boiler
    Have any of you guy's installed Central Boilers dual fuel boiler, how did it go, are they a good product?
    S Davis
    Apex Radiant Heating
  • S Davis
    They are a water jacket boiler that is wood fired and you can back that up with NG/LPG/OIL, they look like a storage shed and you just drop them on the ground and run under ground supply and return lines to the building, Their web site say's they have been around since 84.
    S Davis
  • S Davis
    Central Boiler
    Ken,
    S Davis
  • Ken_8
    I checked out the website,
    The fact that the boilers maximum out put (their smallest model) is a qurter million BTU's and ensconced in a "shed" bigger than my A-Frame in northern VT was an instant turn off. I can just see the smoke pouring from the chimney leaving fly-ash all over the pristine snow, my truck hood and vermin living in the voids come spring.
    But then, what does a "city boy" like me know about wood boilers(:-o)
  • S Davis
    soot
    My thoughts exactly but I have a customer that wants me to design and install a radiant system using one, he drives a log truck so I guess he can get cheep wood.
    S Davis
  • Leo
    Leo Member Posts: 772
    They Smoke up the neighborhood. They are a nuisance. Not to mention they can burn half a forest at one time. They are an open system so you don't see a relief valve and notice how they are set a distance from the house. The first one I saw was at a farm and I thought it was some sort of a smoke house.
    Leo
  • Blackoakbob
    Blackoakbob Member Posts: 252
    There are many extras.....
    one is a light on the front so the nieghbors can see your dumba-- out there at 2 am, at minus 20F trying get up some heat for the house! HA! HA! HA! If you what to be practical and warm look into the ones with large volumes of water for longer times between firing. Best Regards.
