leaking radiant
ed wallace
ed wallace Member Posts: 1,612
looked at a possible job today 35 yr old home has radiant thats not holding pressure new addition is being add to the home boiler being moved to a new utility closet in middle of house in nerw addition was asked to cut off the manifolds and move them to new boiler room 3 old bedrooms to get new thick pads and carpets these rooms will no longer be supplied by radiant new hydro air to be added to heat house in addition to radiant oil tank not to be moved or replaced radiant leak not to be fixed can you say someone is clueless
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
