sizng a pool heater
grindog
grindog Member Posts: 121
iam sizing a new boiler for heating a 25,000 gallon pool and piping a radiant zone in a 2000 square foot basement. What is the btu take off for the swimming pool and can i use a flat plate heat exchanger for the pool or would i be better off using a indirect hot water heater to gain more volume. thank you
  • Kal Row
    Kal Row Member Posts: 1,520
    it takes 1btu to raise 1lb of water, 1degree per hr...
    there are 8.33 lbs in a gal, so the pool has 208,250lbs
    a 250 unit should do fine, but dont even think of starting that process untill you have straight sunny days - you will loose heat faster than you are putting it in and never get it to 84
    i recomend the sta-rite heater
  • Kal Row
    also about the flat plate..
    it would have to be huge - for the flow rates involved - and need a filter - dont do it!!!
    put the radiant zone on a seperate small hot water heater,
  • Al Letellier
    Al Letellier Member Posts: 781
    heating pools
    I believe that too many pool heaters are way oversized. Remember that you only have to heat it up once and then you just maintain temp. A good solar blanket will keep in the heat. We have an application where the pool is 20x40 inground with 10' deep end, in Maine, and we are using a 3 section 100MBH boiler with a small tank type heat exchanger. We have a second tank type pool heater for a spa, and the pool heats up from 40 to 80 in about a day and a half, and uses only 250 gallons or so for the entire season. Oversizing will only heat it up faster and then be really inefficient and will short cycle all season.
  • Al Letellier
    heating pools
    Check out SuperStor. I believe they give a formula for their heaters.
