Boiler Pictures Nice Install's
RoosterBoy
RoosterBoy Member Posts: 459
can you guys post some of your nice boiler or heating cooling installs I enjoy looking at them
thanks
  • Al Corelli
    Al Corelli Member Posts: 454
    I hesitate to post my pics, because sometimes a straight pipe looks crooked in the photos when it isn't.
    We have photos of most all of our boiler installs and many of our plumbing jobs.
    Plus, all of our radiant floors have detailed pictures of tubing layout.
    I'll post, but don't make fun. I just started doing this last week and I might get shy and let the helpers do all the work from now on... :)
    Pic of Buderus was recently.
    Attached pic is of radiant job from last year with 7 different temps for an old house. Customer wanted "none of that electronic whizz crap" and basic thermostat control. Therms are Wirsbo, as is all the radiant gear. Picture shows one "pump rack" for kitchen side of hoouse. There is another for the master bath area, including a radiant wall to keep the mirror from fogging.
  • Al Corelli
    I better try to bring the pic size down some.
    That's another reason I don't post pics... I ain't good at posting them.
    I swapped the photos to keep everyone's screen from going nuts.
  • Al Corelli
    More pics
    Here are some more.
    These are from some of our latest jobs.
    They range from small gas hot water boilers to mid-sized commercial steam. There is also a picture or two from a smowmelt job in Greenwich running a Pinnacle and Wirsbo (Tekmar) snowmelt control.
    And, NO! I didn't install the WM Gold boiler. We just repiped it so it would make heat.
    Steamhead Member Posts: 18,193
    The ones I'm most proud of
    can be found here, along with equally nice ones from several different Wallsters:
    http://www.heatinghelp.com/library.cfm#Steam Piping
    Consulting
  • Al Gregory
    Al Gregory Member Posts: 259
    Here's one we installed a few years ago. This is what it looked like when I went back for the first time a few years later. Filter was clogged. Unfortunatly this is what most of the basements around here look like.
    The other is a hot water job. The aqua booster was already there
  • R. Swatton
    R. Swatton Member Posts: 86
    Install
    This is an application where I used 2 Munckins. One controls the high temp and Super Store and the othe controls the radiant. On the high temp boiler I installed a fixed temp mixing valve for a little higher temp for the bathroom floors, using a progresive re-set.Two separate system with 3 temps.
    Both boilers have Vision I controls that operate the out door re-set and DHW priority
    Rich Swatton
    Summit Plumbing and Heating
    Authorized Heat Tranfer Products Sevice Agent
