Insulate small diameter PEX tubing?
Rodney Summers
Member Posts: 748
absolutely NOT true with steel or copper tubing in the 3/8 or 1/2 or 3/4" sizes
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Insulate small diameter domestic PEX tubing?
For potable water: Does anybody out there insulate the small diameter PEX tubing between the manifold block & the fixtures. Why not insulate the cold tubing for sweating, and insulate the hot for energy conservation? Would armaflex work, or is it just not worth the trouble?0 -
Insulate
I insulated the 3/4" pex tubing from my domestic hot water tank to DHW manifold (home run system). With the expansion and contraction the insulation would open up quite often till the "glue" was no longer effective. I then used black electrical tape and plastic wire ties. Lots of effort, would hate to have to do all of the pipes.0 -
to insulate or not
There isn't an energy savings in insulating small diameter tubing since it increases the outer diameter of the tube. It's hard to explain here but it's covered in college heat transfer courses. It has to do with the insulation increasing the surface area of the tube which causes the convective heat losses to go up. Below about 2" OD it's a loser. I suppose it's ok to prevent sweating though.0 -
end of insulate PEX thread
Gentlemen - thank you for your help. I appreciate it very much. This thread is closed.0
