Snow Melt & Mecadum?
Tim Doran
Tim Doran Member Posts: 208
I usually recommend putting the tubing in the base which usually is crushed limestone, crush refine, or sand. 2" to 3" will do the trick. Attach the tubing to 6"x6" welded wire mesh @ 6" on center. The conductivity of this assembly is not as good as an embeded concrete application but it will still perform well. We can work up the calculations for you. Give tech services a call on Monday or give me a call. My new office number is 631-537-5767.
Tim D.
