Montgomery Ward
Scott Kneeland
Scott Kneeland Member Posts: 158
Don,t even worry about the btu rating of the old boiler it doesn't matter. You did not say if it is steam or hot water? steam you need to size it to the connected load (measure the steam radiators. If its hot water do a heat loss and size it correctly. Remember this is 2005 not 1950.
good luck
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=339&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
