Montgomery Ward
Scott Kneeland
Member Posts: 158
Don,t even worry about the btu rating of the old boiler it doesn't matter. You did not say if it is steam or hot water? steam you need to size it to the connected load (measure the steam radiators. If its hot water do a heat loss and size it correctly. Remember this is 2005 not 1950.
good luck
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=339&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
good luck
MONTGOMERY WARDS BOILER
MODEL # SHL712. WHERE DO I FIND INFO. PLANNING ON REPLACING BOILER. BUT THATS ALL THE CONTRACTOR CAN READ. HELP A BROTHER OUT.
(THE FUTURE)0 -
Probably a Dunkirk,but do a heat loss and who cares what size the old boiler is.
THANKS
I'M SET UP TO MEET THE CONTRACTOR AT THE JOB AND DO AN ACCURATE HEAT LOSS. FYI. HOT WATER NOT STEAM.0 -
heat loss
Shaun, You can get a FREE heat loss program on this web site, it is easy to use and you can check the contractors numbers.
heat loss
Skip the Bill Nye part his name came up by error
- 167 Indoor-Air Quality
