Surging pressure guage on hot water boiler
I just got back from a sevice call on a older Weil mclain gv-6 boiler. Pretty typical call found a defective zone valve. But I noticed when I started the boiler back up the pressure guage needle pulsated for a bit and then settled down. The needle settled in at 20 lbs. Any ideas what could be causing this?
