Vapor guage
ThermalJake
ThermalJake Member Posts: 131
for a steam guage that will measure up to 1 lb of pressure and down to 1 lb of vacuum? I would like a large face and a bottom tapping, as the current Dwyer Magnehelic is tapped high up in the rear, and it collected condensate(it was not rated for a high enough temp either.
Also, Noel I tried you today (you may have gotten a message). I'll try again on Monday, or you're welcome to try the # I left on the voice mail.
Thanks
Jake
