Electro-Temp boiler
Nick_19
Member Posts: 1
They were made by Heat-Timer Corp., but haven't been available for many years. Burnham makes something very similar, but they max out at 20KW. Burnham Carefree model E420. The HC40 was 40KW.
Electro-Temp brand of boilers
Has any one heard of Electro-Temp boilers. Have a HC-40 ( 240v, 1-ph ) 15+ years old needs repalcement. Is it still made ? If not who should I go with ?
TheFuture
P.S. My contractor just started doing a parade house with infloor heat just for the basement ( Viessmann ) Should be posting pictures on the wall soon.0 -
Is it leaking?
if not everything else should be rebuildable.
Contactors and controls are off the shelf. Chromolox manufactures elements for just about every application. Many electric boilers use standard hw tank elements.
If it has to be replaced look into new style modulating electric boiler. Electronic control technology does away with noisey and maintenance intensive contactors. Light dimming issues go away also
hot rod
super hot
/super hot makes electric boilers as well 3or 4 sizes0 -
Question Heat Timer Boiler
Have a working Heat timer boiler mod HC20 has 4 5k elec elements. Where could I find a Sequence timer to fit. or replace it with. Will not fire the number 2,3,4 element to heat. so almost no heat received.0
- 396 Solar
