Anti-Fatigue mats........................(Starch)
brad rutherford_2
Member Posts: 10
If you are using rubber mats the R-value should be low. The manufacturer might have an R-value rating.
Has anyone.................
.........given any thought to anti-fatigue mats on a concrete radiant floor and their r-values?
Is there such a thing as a "radiant-friendly" mat?
I realize that most of them are small mats, but I have a situation where one could be used in my store, and it's in a corner of the building near the end of a heating loop.
Thanks,
Starch0 -
At my shop workbench
I put down a couple rows of this sport court type tile. It is an open mesh type plastic so the heat flow is unrestricted. It's been in about 8 years now. the only thing that bothers it is weld spatter ofr hot copper fittings dropped on it
Probably not as gushy as foam, but much nicer than hard concrete.
What about that thin slab rubber carpet underlayment made for radiant. I had one sample that was made from recycled tire material. About 1/4" thick, fairly tough stuff. The RPA Floor Covering Guide has a bunch of radiant carpet underlayment manufactures listed in the back.
Or a web search.
hot rod
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
