NO electricity -- Hydronics for the AMISH
MGSarkozi
Member Posts: 4
Has anyone ever used 12 volt batteries and an inverter (120V) to power the controls, pumps, etc. for a hydronic system? I have an Amish customer and we are going to use an outdoor wood boiler. I'm looking for sources to find batteries and other componets.
Thanks
M. Sarkozi
Thanks
M. Sarkozi
Why not run gravity hot water and just use 12-volt relays for the burner?0 -
Or
just run it all on 12V and skip the inverter. Laing make a fair selection of 12 V pumps. El Sid and Marsh also. Plenty of remote cabins run on 12V and solar panels.
hot rod
This is a pretty good...
... source of hardware. http://shop.altenergystore.com/index.htm
Yours, Larry0 -
In our area
> batteries and other componets. Thanks M.
> Sarkozi
In our area
the amish run gravity radiant systems off Burnham boilers with millivolt controls. I believe the amish have an exemption to use the millivolt.0 -
Amish Radiant powered by air......................
The Amish use air to power the circulator. They use a thermopile to power the aquastat and gas valve.
Heres a picture of an Amish radiant system.
JR
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"I am the walking Deadman
Hydronics Designer
Hydronics is the most comfortable and energy efficient HVAC system.0 -
they don't use
a circulator in the systems around us. It's all done by gravity.0 -
I think it is all up to the religouis leader
Steve,
I think it is all up to the religouis leader. What he says goes. Some comunities can use air compressors some can't.
JR
Hydronics Designer
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
