Munchkin in calgary
Nron_9
Member Posts: 237
Was the coures a good one? , tried to get in but was told the course was full , is there going to be another one soon I would like to make sure i am on the list , not every one can afford viessmann , and I will only recomend products I know , and can service ,
Munchkin
Seeing as you're in Calgary have you looked at the "Trinity".It's supposed to be similar to the "Munchkin"and the company is Canadian.Check them out at www.nythermal.com
Good Luck
Brian0 -
have seen them
I have used the Nti on a few jobs , had 1 combustion fan fail in the first 3 months of operation , they are what I would call the entry level for condensing boilers , they are easy to install and come with basic control system ,but it is asways good to have more than 1or 2 selections in your data base ,0
