Need Advice
Henry Nel
Member Posts: 1
Hi
We are remodeling a 80 year old house in Seattle. I need some advice regarding heating. I almost decided to put electric under floor heating in the basement and the bedrooms, but last night someone told me I could install a hydronic radiant heating system in the ceiling of the basement and that would heat the basement and the main floor. Is this true and how difficult would it be to do that?
We are planning the replace the basement ceiling in any case.
Henry
Henry
Let's put that in the maybe column
A system like that would be very uncontrollable. It would be better to get a hydronic knowledgable contractor to stop by, look over your home and do a heat loss calc for you.
With this info you could build a system that would be able to heat the up and down spaces accuratly and efficiently.
Check the Find a Contractor feature at this site to get some local advice.
hot rod
Call..
Call Paul Pollets at Advanced Radiant Technology (206-783-4315). He'll take care of you. -DF
Heatloss calc
Henry,
If paul is to busy to get to you I would be happy to help, I can be reached at the numbers below.
Apex Radiant Heating
Stacey Davis
Office 360-336-1924
Cell 360-239-45850
- 167 Indoor-Air Quality
