Plugging 1/8\" Holes
Dave_64
Member Posts: 4
I need to plug 1/8" holes on my returns (one pipe steam system). I assume the returns are iron pipe, similar to the mains, etc. so does that mean I need to use iron plugs? The vents I'm removing certainly are not iron so I would assume it's ok to use a different material. My local hardware store only carries brass plugs in this size but I know I can order the iron plugs online. Does it matter?
Go Brass
Brass with a little pipe dope is best if you ever want to easily remove any of those plugs. I always like seeing brass when I unthread anything from an old steam system, or old car exhaust manifold nuts.0 -
nope
It makes no difference in most cases i don't see any promblem just use a little sealant peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Plugs
I'd go with the brass.
The more important question is.. why are you removing the vents?0 -
Because...
I received advice here on the Wall that since the mains are adequately vented the returns should not be...0 -
Carl
this vent was on a two-pipe/air-vent dry return (the rest of the system is one-pipe). The corresponding steam main will be properly vented as will the rads themselves. Venting the dry return in this scenario can cause banging, since these returns were never sized for steam.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Return Vents
Steamhead - I thought you said to plug all return vents if the main vents were properly vented. I first asked you a general question about this, to which you replied
"On a one-pipe system with proper vents at the ends of the steam mains, you don't need return vents. Take them off and install 1/8" plugs in the holes"
I then asked about the returns on the indirect radiators and you said to plug those as well so I was planning on plugging all return vents. Now I'm confused. Can you clarify? To refresh your memory, look at the "Return Vents" thread from earlier in the week.
Thanks for all your help/advice and I apologize if I've been confusing on this topic...0 -
Same thing
The best placement for main vents is near the end of the steam mains. On a one-pipe main, you can get away with putting the vent on the return, but it's not the best place as you will be filling the return with steam unnecessarily.
The part of the system feeding those indirects is actually "two-pipe air-vent", since each indirect has a vent on it and a return line going into the dry return with no trap on it to stop the steam. You definitely do not want steam getting into this dry return since, unlike the dry return on a one-pipe system, filling this one with steam can cause banging, and this will happen if the return is vented. This setup is shown in the first three pages of Chapter 15 of Lost Art.
So vent the steam mains and plug the holes in the returns as we discussed earlier, and watch how much better it works.
Consulting0 -
Thanks Again
Excellent. Thank you, as always. You've been an incredible help!0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
