Good Lil' Munchkins?
Garett
Garett Member Posts: 13
Anyone have a good little Munchkin story. (Enough about mouse turds) How about Visons I, II, and III controls. I'm planing my first T80 install and was looking her for information.
Thanks
  • Weezbo
    Weezbo Member Posts: 6,231
    well....i been looking to get a class on 1,2,3 here for over a..
    year and a half ..maybe more.. good luck.
  • Chuck Shaw_2
    Chuck Shaw_2 Member Posts: 68
    Gee Weez
    If you had read some of the other posts on the wall, you would know I am going to be in Alaska the 2nd week of June, contact Mechanical Sales in Anchorage for the details.
    Chuck Shaw
  • Ed Goldner, NJ
    Ed Goldner, NJ Member Posts: 25
    Munchkin Training classes
    for anyone in the northern NJ area are being held by Universal Supply Group. April 5th in Wharton, April 6th in Fairlawn. Interested parties can contact Christie Finn at 732-246-0088 or fax 732-246-0517. Fee of $75.00 is required. Tell her Ed Goldner sent you and it's $150.
    If anyone is having a problem with combustion mixture on start up as I did with my T80M w/ Dungs gas valve, a more detailed setup proceedure is available on the Karl Dungs website. You need to look up the GV model under residential gas controls.
    Oh, and definitly add an OD reset sensor.
  • Troy_3
    Troy_3 Member Posts: 479
    Vision system controls
    The munchkin combined with the vision 1,2,3 controls give you amazing control options. You can control multiple boilers with multiple temp. zones all running on their own outdoor resets and all this integrated to the modulation of the boilers. Trying to get outside control systems to work with modulating multiple boilers has never worked this good for me. Try it you will like It. IMHO
  • clammy
    clammy Member Posts: 3,242
    Thanks Ed
    Thank you Mr.Golden i was waiting to be notefied but no one got in touch with me i missed the last class so this time i shall be there and finally i can get the vision packages with out hassling my buddies who made it to the early classes and then i just a toss up between puttting in the munchkins or spending the extra coin and getting a buderus gb142 but after the sticker shock of the buderus for a couple of extra bucks i could get a viessmann i believe .Thanks again for that post peace clammy in nj
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
