Diaelectric unions??
Matt_29
Member Posts: 12
I would like to use a diaelectric union to join some copper to steel piping for a 180 degree residential closed hot water boiler system... are they suitable for and/or do they even make them for this type of application
In My Opinion
You would be better off using a dielectic nipple or a brass nipple. Victaulic and groovelok both make threaded dielectric nipples. The need to use a dielectric connection in a closed loop system is debatable. Dielectric unions ,as a rule, pardon the slang, suck.
tom0 -
Dielectric unions
should not be used on closed loop hydronic systems, especially high temperature ones. That rubber washer will fail in short order.
If your nervous about electrolysis, use a brass nipple between the copper and galvanized pipe. We use a male adaptor and tie the two together directly.
Dielectric devices need only be used for domestic water systems.
I have been
Installing boilers for twenty plus years with Black Steel headers and copper runs. I have never used a dielectric fitting.
Not needed.
Scott
Transition..
Dielectric unions (as Allen mentioned) do not stand up well in especially high temperature hydronic applications. We use a simple all brass ball valve which in a way kills two birds with one stone.
Robert O'Connor/NJ0 -
Scott's right
The entire concept of dielectric unions and fittings is mis-understood and completely over-blown with regard to our particular discipline. We mix aluminum, steel, iron, non-ferrous metals of all kinds and platstics with little to no "dielectric issues."
Issues of way off neutral pH and anode/cathode interactions of "active" metals is more for the labs than general heating. Electrolysis per se is not an issue in what we do.
Of course as soon as I dismiss the issue - someone will remind me of the time they had vinegar heated in a galvanized brine tank and mixed it with aluminum tubing pumped with a zinc and lead circ. pump into a tin vessel filled with enriched uranium and I'll be made the fool once again...
Dielectric flanges!
I used to build these when I had a brass flange business years ago "Smart parts for Neat Heat"
I used a 3/8" bolt and some high temperature and strength washers. Then I sleeved the bolt with either plastic tube or two layers of heat shrink tubing. Then a flat EPDM gasket in between.
All simple off the shelf components, these days, if you need a mechanical joint and dielectric to please an inspector or something.
hot rod
