Taco twin \"T's\"
Weezbo
Member Posts: 6,231
with the Taco Twin "T's" ?
huh?.......*~/:)
goto taco-hvac then products/systems/the loadmatch system
to me the bigest advantage of the twin-T...
over regular closly spaced t's, is that, the twin't is not only flow rate decoupled, but flow direction decoupled as well
so you can put it into systems where you do flow reversal for system eveness - which is always a problem with close t's, the first set of T's get the hottest water
with TWIN-T system-a - you need to, but can, reverse the flow for even supply temps,
with system-b (close-t crossovers on a resverse return) - you set it and forget it
in the end, i am actually doing this with c.pdf0 -
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
