Weil Mclain parts
B. Tice
Member Posts: 206
Does anybody know anyplace that may have parts for 68 series boilers? These parts have been discontinued by WMC . I need a blank coil plate, specifically.
wm part
any good heating contractor can get you a plate they are still availiable afer market0 -
look around
sounds like your removing the coil? well you can cut the coil off and plug the taps. but look around, many places can still get them. there is a company in NY called Wallace Eanace0 -
blank plates
You can order blank plates from Thermoflow, just as you would a replacement coil. See your local supplier
i have a slightly used(maybe 2 seasons) plate for a 68 if you want to pay shipping its yours im in N.Y. 105660 -
Parts
Thanks Al, I thought of Everhot not long after I posted this and found out it was a big item for them. This is for a 268 that had a blank plate from the get-go, but it is very eroded due to a leak.0 -
We do
We are a WM dealer, I can get about anything for 68 series.
Steve0 -
What about middle sections
for the 68 series ? We have alot of front and rear sections , as well as all the O rings and jackets . Can't put anymore together without the middle though . Thanks .0 -
RON,
WE CAN GET PARTS SUCH AS COILS ETC. BUT SECTIONS ARE OBSELETE. I CAN CHECK WITH MY FACTORY REP AND SEE IF HE CAN LOCATE ANY THEY MAY STILL HAVE IF YOU WANT. IT'S A SHAME BECAUSE THE 68 WAS A GREAT BOILER.
SORRY
STEVE0 -
RON
WEIL MCLAIN IS HONORING WARRANTYS ON 68S BY SENDING A WTGO OR WGO BLOCK AS A REPLACEMENT.
STEVE0
- 167 Indoor-Air Quality
