Weil Mclain parts
B. Tice
B. Tice Member Posts: 206
Does anybody know anyplace that may have parts for 68 series boilers? These parts have been discontinued by WMC . I need a blank coil plate, specifically.
  • ed wallace
    ed wallace Member Posts: 1,612
    wm part
    any good heating contractor can get you a plate they are still availiable afer market
  • Michal
    Michal Member Posts: 213
    look around
    sounds like your removing the coil? well you can cut the coil off and plug the taps. but look around, many places can still get them. there is a company in NY called Wallace Eanace
  • Al Letellier
    Al Letellier Member Posts: 781
    blank plates
    You can order blank plates from Thermoflow, just as you would a replacement coil. See your local supplier
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    i have a slightly used(maybe 2 seasons) plate for a 68 if you want to pay shipping its yours im in N.Y. 10566
  • B. Tice
    Parts
    Thanks Al, I thought of Everhot not long after I posted this and found out it was a big item for them. This is for a 268 that had a blank plate from the get-go, but it is very eroded due to a leak.
  • STEVE N
    STEVE N Member Posts: 48
    We do
    We are a WM dealer, I can get about anything for 68 series.
    Steve
  • What about middle sections
    for the 68 series ? We have alot of front and rear sections , as well as all the O rings and jackets . Can't put anymore together without the middle though . Thanks .
  • STEVE N
    RON,
    WE CAN GET PARTS SUCH AS COILS ETC. BUT SECTIONS ARE OBSELETE. I CAN CHECK WITH MY FACTORY REP AND SEE IF HE CAN LOCATE ANY THEY MAY STILL HAVE IF YOU WANT. IT'S A SHAME BECAUSE THE 68 WAS A GREAT BOILER.
    SORRY
    STEVE
  • STEVE N
    RON
    WEIL MCLAIN IS HONORING WARRANTYS ON 68S BY SENDING A WTGO OR WGO BLOCK AS A REPLACEMENT.
    STEVE
