Thermostat with Fan Cycle
Big Ed
Member Posts: 1,117
Does any one know of a thermostat that can be programed to cycle the fan only?
Cycle
Ed, maybe I don't understand your question but why not use any regular stat and a relay. Control the fan just like a pump. bob0 -
The new VisionPro stats...
have the usual auto and on feature, but also a "circ" feature that can be programmed into each of the 4 daily periods, or initiated manually. The fan runs 10 minutes every 30 minutes, regardless of a call for heat or cooling. This feature helps get the maximum benefit from electronic air cleaners or higher-end mechanical filters, prevents stagnation and stratification. It's also useful when cooking or if you're have a large number of people over, and if you permit smoking in your house. The VisionPro is available from any Honeywell distributor.0 -
Thanks
Thanks Guys.....0
- 50 Industry Classes
