Leaking zone valves
Ewan
Member Posts: 45
Hoping you can help me...
I have Erie PopTop-series zone valves with 1/2" sweat connections installed on a 4-zone control board. I'm currently pressure testing the board, and have found 2 of the 4 valve bodies are leaking at the bottom of the body (at the interface between the large-hex bottom plug and the main cast body).
I tried carefully tightening the bottom plug on one body and it slowed, but did not stop the leak.
Any suggestions on how to proceed? Should I remove the bottom plug completely, clean, dope and re-install? Have I pooched the bodies while sweating the connections?
Many thanks in advance.
In Reply
Certainly, unplugging, dopeing the fitting and re installing is certainly the most inexpesive way to try and fix this problem. If the fitting is rusted or has any type of build up un the threads or if the threads are cross threaded, this may not be your Solution. Replacement may be the answer, but trying to repair it is certainly the first step. Don't forget to purge the system afterwards. Good Luck!0 -
P.S.
If you do not know enough about boilers, such as releasing pressure, purging, etc. Please think about calling someone for help. A simple mistake could mean "No Heat" and Frozen Pipes, depending on where you live. I'm not trying to scare you, but what if after you shut down the boiler, you can't get it re lit? Do you know what to do?0 -
Air test?
I was installing a system several years ago, with erie valve. We air tested the system, and it was something like 18 valves out of 20, were leaking from the body. Contacted erie and was told, the valves would not hold more than 10 psi of air pressure. Something with the O rings.0 -
Thanks JackMack
for your reply.
Appreciate your words of caution. Fortunately, the control board (with the leaking zone valves) is on the bench and isn't hooked-up to anything except a bicycle pump
will only hold water...
it's like the o-ring on water filter housings - they let the air out and hold the water, dont tighten the plugs too much, loosen and tighten until the water just stops, o-rings hold back pressure as long a the majority of the o-ring is against something solid and only a couple of atoms worth hold back the pressure
think of o-rings this way
PerSquareInch with the "square" being the key word - it's exponential - a few atoms worth of a "square", is a tiny fraction of the square, and thus only has to hold a tiny fraction of the PerSquareInch'es of pressure, if you wrench it down, and you have increased the contact area exponentially, but the strength of the rubber by compression, has only increased linearly (if that much) and is lagging way behind in the required square strength
Even worse, the deformation of the perfect circular cross section, changes its whole strength structure for the worse
- IT'S NOT A GASKET!!!
This is a recording people just dont get o-rings
The Morton Thiokol design engineers that build the solid rocket boosters get it, and they seal the pressure that creates 1.5 million pounds of thrust at the nozzle with a tiny o-rings, but the decision makers before the shuttle disaster - did not listen to the engineers that said that ice formation could compromise the o-rings physical support structure and the rest is history, the only design change they made afterward is a better caulk to keep water condensation out of the o-ring area and prevent freeze deformation still using the same o-rings aint nothing wrong with them
Terrific Kal...
... many thanks for your reply.
Certainly puts my mind at ease... wasn't too pleased watching air bubbles pour out of the valve bodies.
Thanks again to all.0 -
Some closure
Happy to report that I ditched the bicycle pump in favor of the garden hose and everything's copasetic. I loosened and tightened the bottom plug as Kal suggested and all's good no leaks.
Gotta love The Wall! Thanks again.0
- 50 Industry Classes
