zoning a residential steam system
Rich Kontny_2
Member Posts: 24
you sure you want to go that route? Why not balance the system and get some slower vents on the zone that are over heating,or in the room that house the stat.
i am looking for a piping diagram for a residential low pressure heating system using 2 2" honeywell zone valves. i had a diagram for this that i got at a seminar years ago, but i must have misplaced it. if anybody out there can help me, i would appreciate it. thank you, bill phillips0 -
If it's steam and not hot water
you do not want to go that way. Much better to go with TRV's or as the previous blog said, change out the vents to adjust how fast they vent air. Vents of course are alot less $$$$0 -
modulating valves.
you would be better off committing suicide and get it over with. keep one zone steam and add two hot water zones.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
