bleeding forever
Timco
Timco Member Posts: 3,040
Thanks to all for great advise...I am now insulated, and pumping away with swing check valves on both sides...Works great!
Question is that one wall mount rad always has the same amount of air in it, every day, but not much. Farthest away from the boiler, end of a zone, highest. I run at 20# and 180. Will this ever bleed out all the way? Had to replace all the water in the system last time due to making new inlet & outlet manifolds, about a week ago.
Thanks again for the great reads, posts, and advise. This is where the pros live and dwell, and the occasional HO.
Tim
Just a guy running some pipes.
