Bleeding radiators.
Joe.G
Member Posts: 213
Hi,I have hot water radiators and I need to bleed them ( did some work to the system) What is hte best way, hot? cold? boiler running with circulator on? and I should start fromte h top and work down right? thanks
I know this may be a dumb ?0 -
it makes no....
major differance....it might have to be done twice. kpc
bleeding
I am an HO myself, but have found it made no difference where you start, as each radiator has it's amount of trapped air already. I also found I needed to bleed them the next day, and a couple days later to be sure I got it all.
TimJust a guy running some pipes.0 -
So what is hte correct way? thanks0 -
depends on how far down you drained the system. if just minor, bleed them all out cold, and run the system. bleed an hour later with everything running and hot, and again the next day. if all the way drained, I run all zones on together for one minute, and re-bleed, twice, to get all the air out of the boiler before firing it up for any time to eliminate boiling.Just a guy running some pipes.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
