Joe@buderus
RoosterBoy
RoosterBoy Member Posts: 459
hi Joe after using my 2107 control for 2 days I must say no short cycle so far the boiler ran once or twice for 2 min but that's not bad. Joe is there anything I can do to fine tune the control even better. what should I look for to fine tune it for better efficiency
thanks
  • Dan_15
    Dan_15 Member Posts: 388
    When we spoke, I suggested you could adjust the "Day Temp" and "Night Temp" setting. With temperatures below 40 or 45 degree's this might not be a good time to try to adjust as most hydro - coils (single speed units) are near required design temperatures of 180 degree supply water. I suggest waiting till milder temperatures before adjusting. Please remember to have the "Night Temp" two degrees lower than the "Day Temp". Thanks, - So about the delay in answering.
  • RoosterBoy
    thanks Joe I cant be more happy with this 2107 control
    I can see it saving money the last few days ive had it in the burner dose not run as much.
    I cant be more happy.
    thanks
