vapor vacuum system
Robert Pastor
Member Posts: 12
I have a broomell trap that needs to be replaced. I was told to remove it and install big vents on the mains. This is a finished basement and cannot get to all the mains. Do I need to put one every main and do I have to install air vents on the radiators as well. If I cant get to all the mains can I replace the broommell trap with a condensate pump.
oh NO, NO
dont get rid of that Broomel trap..it has no moving parts...just clean it..gwgillplumbingandheating.com
I forgot to tell you some one had removed all the guts a long time ago and the unit keeps pushing out steam from the boiler because there is no float ball inside. They also want to change the boiler at the same time we fix the trap or replace it.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
